Salta al contenuto principale
The Chevrolet Cruze is a compact car made by the Chevrolet division of General Motors. The Cruze was first released in 2008 with a front-engine, front-wheel-drive layout.
How do you remove lower steering column cover
The ignition key is stuck in the ignition. I've tried the key release with no luck. I need to remove lower steering column cover to see what's going on. How do you remove the lower cover?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
There is a key removal bypass underneath the keyhole to remove the key when this happens. I pulled up a video for you that shows you how to use it to remove the key.
https://www.youtube.com/watch?v=UNVbCakt...
Hope this helps!!
Cheers
Monte
Punteggio 0
Aggiungi la tua risposta
Dane Justice sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 306
