Salta al contenuto principale
Rilasciato il 20 Settembre 2019, il Nintendo Switch Lite è una versione più economica e solamente portatile della console Nintendo Switch, dispone di controller Joy-Con integrati e di uno schermo leggermente più piccolo.
20 Domande Visualizza tutte
What is the safest way to power down my device?
So recently my switch just got the error code 2165-1001 and the error message specifically says to power down the console using the power button. However, my console's power button hasn't worked in about a year, if not longer, and I haven't had a chance to replace it myself or the opportunity to get it fixed. Is it safe to let the console die and then charge it? Or is there a safe way to power down the console in this case? Again, I cannot use the power button as the power button does not work.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
An update for this: I went to bed and when I woke up in the morning my switch was dead. I plugged it into the charger and it started working again. Now I just gotta figure out how to fix the power button.
Punteggio 0
Can you try holding the home button to get into the power menu?
Punteggio 0
1 Commento:
Unfortunately the error message made it so that way I could not use the home button. Also the power menu on the switch lite only allows you to put the console to sleep and not turn it off.
I went to bed before your answer was posted so I hadn't seen it. However, my switch died in during the night and once I had plugged it in to charge it, it was completely normal. The thing I have to focus on now is replacing the power button.
da
Aggiungi la tua risposta
Eros sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 150
