Salta al contenuto principale
How to put out the battery?
Hi, I want to replace the screen myself. But I have a question; Before you can put out the battery you should heat the phone I see on video's. How long and what temperature, and can I use my iron of hairdryer for it?
Should the battery be empty (for safety)?
Thank you
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@v1987 the most common temperature for that is between 80 and 100 degrees Celsius, with 80 degrees Celsius being somewhat the standard. Don't go to high or you can actually damage your phone. If you stay in that temperature range, you do not have to worry about the battery.
Iron, no. You can't control the heat very well. Hairdryer , yes. If it reaches the temperatures.
Punteggio 1
Aggiungi la tua risposta
V1987 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 12
Tutti i Tempi: 330
