Salta al contenuto principale
Robotic vacuum released in May 2014 with various cleaning features. Repair is similar to the iCLEBO Pop, and disassembly requires only basic tools.
Error Code C2 after 2-3 mins on hardwood and carpet
How can I fix an Iclebo Art YCR-M05 that stops within a minute or two of starting to vacuum with error code C2 "Cannot detect floor" on any floor type?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@feli86116 sounds like you are getting this error based on a stuck wheel. Since iFixit does not yet have a guide for that, use something like this video to work on it. Check the drive wheels etc. Could just be a bunch of debris that is clogging things up.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Punteggio 1
2 Commenti:
Many thanks for this. I was unable to videotape my (only partial) dismantling of this unit as I don't have a "selfie" stick or any way to video such an activity without somebody else holding my phone. Apologies. I just put it back together and, unfortunately, it's "C2" error message came up just the same as before. I was, however, able to remove some dust and hair but there wasn't alot and none around the wheels....so, I'm back at square #1 ....
da
@feli86116 lets see if we can find out which sensor/wheel is responsible for that.
da
Aggiungi la tua risposta
Feli sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 17
Tutti i Tempi: 293
