Salta al contenuto principale
The Fitbit Versa 3 is a smartwatch released on September 25th, 2020. It features a larger display and built-in GPS.
Why does my replacement battery not charge?
I have now replaced the battery in my Versa 3 twice with an iFixIt product. Twice now I have followed the instructions and successfully insert the battery(s) and proceeded with the charging instructions. Both batteries have charged to 100% then they quickly drain to below 36% and when connected to recharge say the battery is too cold to charge. Is this something anyone has been able to remedy?
Questa è una buona domanda?
Punteggio 0
1 Commento:
It has powered on with 2 separate replacement batteries, but continues to drain quickly and slowly charges with a "cold battery" warning.
da
Aggiungi un commento
1 Risposta
Has the Versa 3 powered on? If it doesn't you may need to see if it is an internal issue.
Punteggio 0
Aggiungi la tua risposta
J Spence sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 175
