Salta al contenuto principale
Model A1347. Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
Three beeps at startup after disk upgrade on a Mini Server
After upgrading the two disks, my mini server won't boot : I have 3 beeps at startup apparently indicating a memory problem. This is not solved by replacing the memory modules by two others.
I've then replaced back the disks by the original ones: the mini boots perfectly with either sets of memory modules.
Is there anything to be done to prepare the disks before installation?
Has anyone experienced that?
Any ideas?
Questa è una buona domanda?
Punteggio -1
1 Commento
What are the makes and models of the new hard drives?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Take out ALL RAM - you should get a blinking light which indicates no RAM selftest pass ok. Replace the RAM try to boot with ONE new disk - (of course you did format the new disks and install OS). Proceed from there.
If this Answer is helpful please remember to return and mark it Accepted.
Punteggio 0
Aggiungi la tua risposta
LHR sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,522
