@elenamarino if anything then you want to use some Optically Clear Adhesive (OCA) since only that can create very thin bond lines. Use it carefully and follow the directions. Ultimately, I would advise you to get a new screen.
Translation
@elenamarino, semmai è meglio usare un adesivo trasparente ottico (OCA), perché solo quello può creare linee di adesione molto sottili. Usalo con attenzione e segui le indicazioni. In definitiva, ti consiglio di acquistare un nuovo schermo.
@elenamarino we would need to see how the screen is separating. From what I envision this looks like, I would gently bend the glass further back. Then using some 99% isopropyl alcohol and some cotton tip applicators, clean the area between the glass and the LCD. Hold the screen so the that alcohol does not drip into the screen but drips to the outside. Once cleaned, apply the OCA as per the directions from the maker. Personally, I would use as little as possible and focus on the outside edges and not so much on the center. Critical areas here will be the opening of the screen to get the OCA in between and to make sure that it doesn't run to the inside of the screen. That could cause Ghost Touch later on. I am keeping my fingers crossed and hope this will work for you. Just take your time when you do this and do not rush into things.
Translation
@elenamarino necesitaríamos ver como se está separando la pantalla. Por lo que veo, yo doblaría suavemente el cristal hacia atrás. Luego con un poco de alcohol isopropílico al 99% y unos aplicadores con punta de algodón, limpiar la zona entre el cristal y la pantalla LCD. Sostenga la pantalla para que el alcohol no gotee dentro de la pantalla, sino que gotee hacia el exterior. Una vez limpia, aplique el OCA siguiendo las instrucciones del fabricante. Personalmente, yo usaría la menor cantidad posible y me centraría en los bordes exteriores y no tanto en el centro. Las areas criticas aqui seran la apertura de la pantalla para conseguir que el OCA entre y asegurarse de que no corra hacia el interior de la pantalla. Eso podría causar Ghost Touch más adelante. Estoy cruzando los dedos y espero que esto funcione para usted. Sólo tómese su tiempo cuando usted hace esto y no se apresure en las cosas.
Votato
Annulla
Punteggio
0
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
@oldturkey03
Sto comprando questo prodotto perché il foglio adesivo è molto costoso, volevo incollare lo schermo per non farlo "scivolare via". Sai indicarmi un tutorial per eseguire bene questa operazione? Grazie mille
Prodotto comprato:
LOCA Colla UV di grande fattura lente di vetro UV colla per telefono cellulare professionale manutenzione negozio per tecnico per telefono cellulare copertura vetro schermo Lcd riparazione
da Elena Marino
