Sony tv KDF-60XBR950 TV will not turn on.
When either power button on unit or remote is pressed the unit will not turn on. Green stand-by light changes to red light and flashes 6 times indicating a problem. Following several attempts, the unit will turn on and operate normally. Is there a fix that the homeowner can perform?
sony tv KDF-60XBR950
Questa è una buona domanda?
1 Commento
@roger30093 as honakrisi already mentioned, the 6-blink error comes from the power supply. Yes, you can do that. Unplug your TV and remove the back cover. You can now see the power board as well as all the other board. Teh power board is the one where the power cord plugs into. disconnect all connectors that lead to the other boards and the LCD panel from the power supply. Then remove the screws that hold the power board to the metal of the TV. Replace it with a new one by reversing your steps.
da oldturkey03
