Salta al contenuto principale
La LaCrosse ha debuttato verso la fine del 2004 come modello 2005, sostituendo la Century e la Regal.
I bought a car with no keys whent bought new key will not pro gram
Starting disable light will not go off even when I do the reprogram sequence
Questa è una buona domanda?
Punteggio 1
2 Commenti:
what reprogramming sequence at you doing? I have the same car and issue!!!
da Condividi
@Cullen Dunn, dealers use a 10 min program using their scan tool but owners have to use the 30 min procedure without Buick's scan tool. Describe in detail what you're trying to do. Year, model, maintenance history, modifications?
da Condividi
Aggiungi un commento
1 Risposta
The key must be a specific type before it will have anything to reprogram. Autos with this type of key you must have the ECU, the immobilizer, and the key all programmed together in order to work.
Punteggio -1
Aggiungi la tua risposta
Guy Daniels sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 32
Tutti i Tempi: 473
