Salta al contenuto principale
A colour printer released in 2015 by Hewlett-Packard. There are two models; A9T85A and A9T87B.
1 Domande Visualizza tutte
freezes up or shuts off mid print
Sometimes when I use it it either completely stops halfway through the print for about an hour before ejecting the half printed page, or shuts off completely and won't turn on unless I unplug it then plug it back in, it also will say that the ink is empty, even if it has a brand new cartridge, also the door sensor is broken and will randomly say that the access door is open even if it's closed
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If it stops half print, seems to be a memory problem.
Try to upgrade the micro software of your printer, if available. If possible add some RAM to your printer
I think the problem is your printer is quite old, and you're sending complex files
Punteggio 0
Aggiungi la tua risposta
ender_user 5479 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 9
Tutti i Tempi: 104
