Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
Weak Signal after replace LCD Display
I changed my LCD assembly, just after that my iPhone have a weak signal o lost signal (no service), think i don't replace the screws at same order. Somebody help me ..! Thanks
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
5 Risposte
Soluzione Prescelta
Please refer to my earlier post here.
Accepted Answer
Included are images of correct screw length needed.
Good Luck.
Punteggio 1
Risposta Più Utile
Hi, look carefully at this thread
wi-fi distance was reduced
and look at the pictures. It is common to forget that small silver piece which gives contact to the wifi. Let us know if that helps!
~asle
Punteggio 1
check connector #7, place a tape on it just to make sure it's connected properly
Punteggio 0
There is a little metal piece "clip" next to the battery connector, Also called the pressure contact. These clip has a small pin that has to be bent in order to touch the back cover of the phone. If not you will have a "No carrier" issue.
Cheers
Erik
Punteggio 0
1 Commento:
[prodotto collegato mancante o disabilitato: IF182-023]
da
try a restore ! even if is the hardest way it works every time
Punteggio 0
Aggiungi la tua risposta
Georges sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 12,052
