Reoccuring Panic Full Crash - Resolves a bit when Pressure on Screen
I've had a screen replacement done recently after a semi full can fell on my iPad screen (on the area above the charging port)/
Information regarding the issue:
- If left alone, it will flash a purple screen (sometimes, not always), crash, then reboot and indicate that it has 0% battery left when it is not empty.
- It will restart around every 3 minutes.
- When pressure is applied on the screen area above the charging port, the battery indicator returns to normal and the crashing halts.
- When pressure has been applied on that area of the screen for a while, it will stay alive for much longer than 3 minutes (it lasted an hour last night).
I do intend on taking it to the repair shop ASAP but could anyone potentially tell me what the problem is?
"panicString" : "panic(cpu 0 caller 0xfffffe00109bdf40): SMC PANIC - ASSERTION FAILED: target\/j61x\/target.cpp:365: 0, SMC BSC failure, spreadsheet ver(*10) 351801\nS.sensor array 0 - 6 is 0x5b, 0x2000, 0x0, 0x0, 0x0, 0x0, 0x0\n\n - Misc(2) OUTBOX2 not ready\nASSERTION FAILED: target\/j61x\/target.cpp:365: 0, SMC BSC failure, spreadsheet ver(*10) 351801\nS.sensor array 0 - 6 is 0x5b, 0x2000, 0x0, 0x0, 0x0, 0x0, 0x0\n\n\nRTKit: RTKit-2413.60.9.release - Client:
This is a snippet of the panic full crash log.
Questa è una buona domanda?
