Salta al contenuto principale
Refresh Rate 165 Hz Brand Acer Standing screen display size ‎27 Inches Max Screen Resolution ‎2560 x 1440 Screen Surface Description Curved
Domanda Chiusa
Why is my monitor giving a random blackscreen via displayport
Why is my monitor giving a random black screen via display port on an Nvidia graphics card while my hdmi connection works just fine
Questa è una buona domanda?
Punteggio 1
4 Commenti:
One common cause of this issue is related to the cable or connection1. A loose or faulty cable connecting your monitor to your computer can lead to intermittent black screens. It's also possible that the quality of the cable itself could be the culprit, as lower-quality cables might not reliably support the bandwidth required for a stable display.
da
@alwaizgroup read the question! "giving a random black screen via display port on an Nvidia graphics card while my hdmi connection works just fine. It's NOT a cable issue. @tech_ni @dadibrokeit nah. Not AI generated. It's to weak for that.
da
@barrysinanan what OS are you using and what driver version is your Nvidia card using? Have you done a recent update?
da
@oldturkey03 maybe a copy and paste from somewhere else lol
da
Aggiungi un commento
1 Risposta
Hi @barrysinanan
If the HDMI connection works correctly then the black screen may be software related and you may have to reset your device that is connected to the display (NOT THE DISPLAY ITSELF)
Curious to hear about the development! Cheers!
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 442
