مستشعر بصمة الإصبع لا يعمل The fingerprint sensor is not working
بصمة ''
Translate
fingerprint ''
Questa è una buona domanda?
بصمة ''
Translate
fingerprint ''
@asimalatefy couple of things you do want to check first. Make sure that you have either no or an approved screen protector on your phone. Some of the cheaper aftermarket once can actually prevent your fingerprint sensor from working. Next you want to make sure it is not software related. Make sure your phone has been upgraded to the latest firmware version.
Then I would clear the cache
Next you want to try and Delete and re-insert fingerprints
Check on here for more on all of that.
If none of that works, you may need to replace the fingerprint sensor flex. It is widely available at many online stores like this (example only and not an endorsement)
Since iFixit does not yet have a guide for this use the one from here
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 43
