Salta al contenuto principale
Il G4 Quicksilver era disponibile nelle versioni da 533 MHz, 667 MHz, 733 MHz, 800 MHz, 933 MHz e 1,0 GHz.
processor upgrade - swap from faster QS - compatibility issues?
Hello!
I have a single processor, 733mhz Quicksilver '01. It's been heavily upgraded, with three hard drives, maxed out RAM, and a ATI Radeon 9800 Pro. I recently loaded Leopard on it, in order to have compatibility with some updated apps I need to run, and it works well despite the unsupported config. Of course, it's very slow.
I found a nice dual-800 Mhz CPU online for a reasonable price, which would more than double the speed of the QS and make Leopard usable. It was pulled out of a Mac somebody is parting out - a Quicksilver 2001 - so it's an actual Apple part.
My question is simple - as it's from the same model G4, with the same bus speed and presumably the same mother board, I would assume it's compatible - but is it? Do I need a firmware or ROM update? Other than that, it should be a simple upgrade once I get it!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione prescelta
I see no reason for the Dual 800 not to work. Since this is from the same series no changes need be made. Here's how to do it: http://fastmac.com/downloads/agp_install...
Punteggio 3
1 Commento:
nice guide, but from what website do i buy the cpc upgrade?
da
Aggiungi la tua risposta
May sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 7
Tutti i Tempi: 3,540
