Salta al contenuto principale
Ninth generation of iPad, released September 24, 2021, available in 64 or 256 GB models. Model Number A2602.
Screen replacement causes lcd to go crazy?
Hey all first time poster, I replaced the screen in my daughter’s iPad 9th gen 10.2” . The replacement went well and nothing visibly went array. It’s my first replacement but I wanted to attempt to do it myself worst case the iPads are on sale for $250 right now. Long story short I replaced the touch screen, I powered the iPad on before finalizing the install so I could test the touch screen before securing above the lcd. Everything worked flawlessly. I got everything put together and powered the iPad on, and the lcd goes nuts. Can’t type in the passcode or anything. It spams the passcode and locks me out. I ordered another touch screen thinking that may be a problem. It gets here tomorrow. But I’m thinking there may be another issue? Possibly lcd? I did remove the touch screen again, I powered the iPad on with no touch screen and the lcd seems to go crazy even without the touch screen attached. Any idea??
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
This sounds like you are on the right track. It sounds weird, but in my recollection, it's normal for the screen to totally freak out without a touch screen connected. I think that started in the iPad 5 or 6? But it's possible the digitizer was damaged during reassembly, or even just that a cable is pinched.
Punteggio 2
Ipad 9gen 10.2 original folder
Punteggio 0
Aggiungi la tua risposta
Hunter Lewis sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 29
Tutti i Tempi: 981
