Salta al contenuto principale
The Canon Powershot A590 IS is an 8 megapixel digital point-and-shoot camera with a 4x optical zoom and a 2.5 inch LCD screen.
23 Domande Visualizza tutte
How is the battery hatch door replaced?
The flip door over the batteries and memory has been damaged. I have a new door, but it came with no directions. I need to know how to remove the old door and install the new door.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The door is held to the front assembly via a small round pin. you will have to use a very small pindriver (a small nail might just work too) and some needle nose pliers to remove it. Watch the small spring that is in the middle of the hinge. A bit tedious and it does require some good eyesight and dexterity. Hope this helps, good luck.
Punteggio 2
1 Commento:
It does not appear to be enough room to use the pin driver.
da
Aggiungi la tua risposta
Sherri C sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,119
