Salta al contenuto principale
A1708 / EMC 2978 — Lanciato nell'ottobre 2016, questo MacBook Pro entry-level conserva i tradizionali tasti funzione (invece della Touch Bar OLED). La versione function key adotta l'Intel Core i5 e 2 porte Thunderbolt.
Very hot and screen is black
My MacBook recently stopped working. I had been running CLion on it, and i closed it to take a break. When i came back, The screen was black, and it was very hot. Any help is appreciated!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Not good! Either you have a process loop which is running your system hard if you haven’t shut the system down or you have a logic board short.
Punteggio 1
2 Commenti:
I have tried to restart it multiple times, so I’m guessing the latter. Do I have any options besides getting a new board?
da
@elvismeng - Repair is what I would look into. It all depends what failed.
While not a repair guide, you can use this to review your board Smontaggio MacBook Pro 13" Function Keys versione fine 2016 for damage. Jump to Step 15 ~ 18. Do you see any burnt components or areas of the logic board?
If this is too much for you to get into there are people with logic board repair skills who should be able to repair your board.
da
Aggiungi la tua risposta
Elvis Meng sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 99
