Salta al contenuto principale
The Dell XPS 17 9710 was released in May 2021. It contains a 12th Generation Intel Core Processor and runs on the Windows 11 operating system.
Screen gets distorted the moment GPU driver is installed
I've just gotten a new 9710 motherboard yesterday and every single time I install Intel GPU drivers I get this:
https://i.imgur.com/jd6KIwR.png
Tried ctrl alt shift b or whatever people said to reset GPU driver, tried different versions of drivers and tried reinstalling windows, all the same. The screen looks perfectly fine right up until the moment where Intel graphics driver gets installed and then this happens. When connecting to an external screen it looks and works fine both when duplicating the display and extending it.
I don't know, think I need to return the motherboard unless this is somehow an easy fix?
Questa è una buona domanda?
Punteggio 0
2 Commenti
Have you contacted DELL ?
da
@aactech no because the motherboard is from a 3rd seller that services Dell laptops
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hi @krpwa
This is a puzzler. It is odd because normally if it was the GPU and the driver then the external display would be also be distorted. Is perhaps the replacement motherboard not the exact match for the old one? Have you looked at both to see if the part number is exactly the same?
Let me get this correct. The screen works fine with Windows generic video driver but goes wierd when the Intel driver is installed? What does Device Manager show for the Monitor before and after the Intel drive install? Your image looks like the frequency of the display is incorrect - but I'm only guessing.
Normally if I think it is just a driver corruption issue I suggest using the Display Driver Uninstaller app which completely removes all traces of video driver and settings.
What does the 3rd party reseller say?
Punteggio 1
if it works fine then there is a graphics driver installed so you dont need to install 1, your just over thinking things
Punteggio 1
Aggiungi la tua risposta
Krpwa sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 144
