Salta al contenuto principale
Il controller PS4 modello CUH-ZCT1. Rilasciato nel Novembre 2013 dalla Sony Computer Entertainment, la sostituzione della batteria da 3.7V di questo "six-axis" non è una riparazione complicata (N.B.: La guida di smontaggio NON è per questo modello)
Wired Connection not working
I have a ds4 controller that works via Bluetooth but is unable to work with a wired connection to the PlayStation and pc. I figured the port wasn’t working so I decided to swap the port with another controller whose analog sticks are broken. This new port works perfectly but when making the swap, the controller still doesn’t show up as a wired connection.
I can provide pictures or answer any questions to help troubleshoot this issue. At this point I’m more intrigued on how to get it working than anything else. Any hardware that I should be looking at that could be the culprit here?
Worth noting: Since the wired connection wasn’t working, i decided to download ds4windows to see how the Bluetooth connection to the pc would hold up vs input lag. During this process, I was changing settings on ds4 along with the controller device in my pc control panel. I disabled a driver that a video recommended during this. Not sure if I might have done something to alter the controllers ability to recognize the wired connection.
Thank you!
Update (01/07/24)
This has been solved. Needed to get the correct usb connection for the controller model. Ordered this online and now the controller works fine.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Punteggio 1
Risposta Più Utile
@lincolnabe0978 copy your update as an answer, then accept it. That way we know it has been resolved.
Punteggio 1
Aggiungi la tua risposta
Brad Riley sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 92
Tutti i Tempi: 2,178
