Salta al contenuto principale
Guide di riparazione e documentazione per lo smartphone Google Pixel 6a con 5G. Lanciato a luglio 2022.
Yellow display due to missing SMD resistor. Resistor value WANTED!
I have a yellow display and it turned out that an SMD resistor on the motherboard had broken out. Unfortunately I don't know the resistance value and I would be super grateful if someone could measure this resistance value. Please write whether you measured the resistance when installed or removed.
The resistor is located directly on the mainboard just below the connector for the display and is covered by this connector as long as it is plugged in.
Immagine
Thank you very much and Christmas greetings 😊
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
1 Risposta
Risposta più utile
I measured the resistance value and size on a second phone. It is a 0 Ohm resistor in a 0402 package. After replacing the resistor the Display is functioning without the yellow cast. :D
Punteggio 3
1 Commento:
Hi Fabian, my pixel has a similar issue. Could you please share a link where I can buy the resistor? Thanks!
da
Aggiungi la tua risposta
Fabian Popp sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 29
Tutti i Tempi: 600
