Salta al contenuto principale
A1708 / EMC 2978 — Lanciato nell'ottobre 2016, questo MacBook Pro entry-level conserva i tradizionali tasti funzione (invece della Touch Bar OLED). La versione function key adotta l'Intel Core i5 e 2 porte Thunderbolt.
Wifi antenna connector broke of completely
I broke of the wifi connector during a repair. Yes, I know i was not careful enough. And it came even worse, when trying to fix it, the soldering iron was too hot, so it snapped off completely. And there was no connection of the middle pin visible. Is there any chance to rescue the wifi? Does anyone has an idea where the middlepin is connected to the mainboard. Is it via multilayer? I scratched of some of the coating, but i can't see any connecting point for the middle pin. Thanks.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
here is an image of connected components
Punteggio 3
11 Commenti:
Thanks a lot. Is U3710 beneath the silver cover sitting right of the connectors?
da
Great! And is silver cover is easy to detach?
da
@denniswienecke im not sure tbh i havent worked on 1 of them boards yet
da
do you know if the connection between the two points and the connector is on a sub level? It doesn't look like it going on the surface?
da
Mostra altri 6 commenti
Aggiungi la tua risposta
Dennis Wienecke sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 14
Tutti i Tempi: 171
