Salta al contenuto principale
Modello A2115 / 2019 / processori da i5 6-core 3.0 GHz a i9 8-core 3.6 GHz. Rilasciato il 19 marzo 2019.
Only the right side of the screen is glowing...
I am working on a person's iMac, but I am stumped. The right side of the screen glows fine, but the left side, not so much. It also looks like there is a bend in the middle, like if there was a bent light reflector.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Shine a light from a flashlight onto the dark side of the screen. If there is an image but faint, the backlight of the LCD is failing on one side and needs to be replaced. If the backlight is not the problem, make sure the LCD is securely connected to the logic board.
Punteggio 2
Aggiungi la tua risposta
Jri-creator sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 129
