Hi Marc,
Well, I have good news and bad news. The bad news is the drop appears to have damaged your lightning port flex cable assembly, but the good news is it's fixable.
The panic log you pulled up gives us the vital clue we need to diagnose your issue right here.
Missing sensor(s): mic1
According to the Kernel Panics Wiki page, sensor mic1 is located on the charging port assembly.
Missing Sensor
Mic1 - Bottom Microphone
Location
On the Charge Port Assembly.
Likely Issue
Charge Port Assembly or its connector on the Logic Board
I'll give you a 90% chance that replacing the charge port assembly will fix the problem. Here's the part you'll need.
iPhone 8 Lightning Connector Assembly
Note that the 2nd generation SE is based on the iPhone 8 and retains much of the same hardware in exchange for an updated processor and motherboard, so the SE 2020 and the 8 use the same Lightning connector assembly.
Here's the guide to follow to replace your assembly.
iPhone SE 2020 Lightning Connector Assembly Replacement - iFixit Repair Guide
That should do it. Good luck on your repair, and let us know how it goes!
Votato
Annulla
Punteggio
0
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
