Why isn't the battery working? I already replaced it with a new one.
Why doesn't the camera battery work, even though it has been replaced with a new one?
Questa è una buona domanda?
@agungpringgo the issue may not be your battery. The issue could be that the camera does not get any power. The first thing to check, would be the fuse that sits on the main circuit board, right past the battery connector. Check that one for continuity.
Use these guides Panasonic DMC-FZ70 to work on your camera. Once you get to the motherboard, post some good pictures of both sides of the board. That way we can see what you see and hopefully help you further. Aggiungere immagini ad una domanda
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 22
@agungpringgo Do you have a multimeter so we can check the voltage of the batteries?
da Andrew S
