Salta al contenuto principale
A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
969 Domande Visualizza tutte
Domanda Chiusa
Is it possible to change/upgrade my Graphic Card on my PC?
Is it possible to change the graphic card on my SATTELITE L750-1T9, I'ts an Intel HD Graphics 3000.
Also will my warranty void if I open the PC??
Questa è una buona domanda?
Punteggio 0
1 Commento
The Intel HD Graphics 3000 services is embedded into the CPU chip. Review this Integrated graphics card in the Sandy Bridge codenamed processors
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
nope, because its embedded to your logic board
Punteggio 1
2nd question: If you have a still alive, good warranty... Yes you would void it.
1st question:I agree with "Wakitech", BUT...I would suggest getting an EXTERNAL [ and connect it to the external video in back of laptop] computer monitor & download the latest software for such], because I suspect you want to play GAMES [ or gaming computer ??!!]
Punteggio 0
Technically yes, But that would involve unsoldering the current chip, and adding a new chip by reballing it on, which if you dont have the tools is literally impossible. I have the tools to do it at my shop (We do PC and game console repairs) and I still have only seen it done successfully 4 or 5 times
Punteggio 0
1 Commento:
The Intel Graphics 3000 is embedded into the CPU not a stand alone GPU. You would need to replace the CPU and then you have the issues of what to use instead of and if the system could even support it. Bottom line here not replaceable.
da
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,296
