Salta al contenuto principale
This unit cools or heats the water it circulates through the ChiliPad mattress pad. Model: CP-CUBE
19 Domande Visualizza tutte
Anyone know thermistor part details?
Does anyone know the specs or replacement part on the thermistor? Mine went bad and I've currently just wired in a resistor to keep it working, but I'd like to be able to control the temperature again with a working thermistor.
Tech support on their end wasn't helpful. :(
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Took a gamble Amazon and found a workable one:
https://www.amazon.com/dp/B07LGMXTKK
Description:
uxcell 2 Pcs 10K NTC Thermistor Probe 15.7 Inch Epoxy Sensitive Temperature Temp Sensor for Air Conditioner
I think the main thing is just finding a 10K NTC thermistor that is waterproof (thus Epoxy in this case).
After putting it in, water temperature was +/- 1 degree off what my thermapen registered. Not bad for $5.49 for two of them!
Punteggio 0
Aggiungi la tua risposta
Jerry Stevenson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 91
