Salta al contenuto principale
The Huawei Y6 2019 was released on March 02, 2019. It weighs 150g and has a 8mm thickness Runs Android 9.0, EMUI 9.1 Has 32GB storage, microSDXC support.
Scheme and Path from battery connector.
Is there a scheme of the power part starting from the battery?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
@essieswifer here is what I have have for the Y6 (not the Y6 Prime)
Huawei Y6 Schematic DiagramHuawei Y6 Layout Diagram
there are a couple of different versions for this phone. If this is not the way your board looks, post some good pictures of your circuit board with your question.
Punteggio 1
مشكلتي هي أن هاتفي له مشكلة بالبطارية يشتغل و ينطفى كل دقيقة
Punteggio 1
1 Commento:
@huaweiy62019 Then you need to start off by replacing the battery with a new one. Once it is installed, re-evaluate and see if that works
Translate
@huaweiy62019 ثم عليك أن تبدأ باستبدال البطارية بأخرى جديدة. بمجرد تثبيته، قم بإعادة تقييمه ومعرفة ما إذا كان ذلك يعمل أم لا
da
Aggiungi la tua risposta
Essies Wifer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 19
Tutti i Tempi: 656
