Salta al contenuto principale
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
hold down the area above F8F9 otherwise black
I need to hold down the area above F8 and F9 without moving in order to turn on the screen. Otherwise, it remains black.
One day when I woke up my MacBook from sleep mode. I found that the screen was black, but the external monitor displayed normally. Then I discovered that by pressing and holding the area above F8 and F9 without moving, the display would work properly. However, once I released the pressure, the screen would go black again.
I can only use the MacBook with an external monitor, but during usage, sometimes the MacBook's screen would suddenly return to normal. As long as I don't adjust the angle of the screen, I can continue using it. However, if I accidentally move it, there is a high chance that the screen will go black again.
Is this a problem with poor cable connection? How can I fix it?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Try checking the LCD cable connection to see if it has become lose Sostituzione gruppo dello schermo MacBook Retina 2015 as pressing above the F8F9 keys indicates that is is then making a connection.
Punteggio 0
Aggiungi la tua risposta
lao3 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 65
