Battery draining overnight when powered off
Hi,
I've bought an iPhone 8 with a dead battery and a slightly water-damaged home button. I've replaced the battery with an iFixit battery, and a home button off eBay. Everything on the phone is now working perfectly fine, apart from the fact that it drains its battery from 100% to 0% in a few hours when it's powered off.
I suspected a (partial) short or something similar, so I powered it down, took it back apart and let the logic board cool down. I then took a photo with my thermal camera and one of the display flex cables is staying noticeably warm even when the phone is turned off:
This only goes away when I disconnect the battery. There is no corrosion anywhere on the logic board, I've re-seated the FPC connectors, and checked that all pins on the connector are clean and straight. I also don't see any knocked-off capacitors or something like this.
Could that heat be the current draw that is draining my battery, and what could be the root cause of this?
Thanks in advance
Questa è una buona domanda?
