Salta al contenuto principale
Essentially, the Xperia 1 II is a more powerful version of the Xperia 1. 'Nuff said.
3 Domande Visualizza tutte
Xperia 1 II stuck in flight mode. Disconnect battery helps momentarily
When trying to make a call, a friends Xperia 1 II displays "turn off flight mode", even though flight mode is not turned on.
Toggling flight mode, re-boots, Safe mode, changing SIM cards, reset network settings, toggling wifi calling, does nothing.
What does work though, is disconnecting and reconnecting the battery. But only after the first start up after the disconnection. As soon as I reboot the phone a second time, the problem comes back...
A diagnostic test reveals UICC failure.
Google says UICC has something to do with the SIM. So my thinking is that some component on a part of the main board that handles network stuff got (water) damaged through a broken screen. And during the startup process it gets flagged as flight mode. Or something like that...
But that doesn't make sense, since everything works fine after the first startup after a disconnection. And that makes me think it can be fixed.
Any takers?
It's stock firmware. So I don't really think that a reinstall would solve anything. But I might be wrong?
Also. I can't get the unit into recovery mode, to clean the system cache. Don't know if that would make a difference though?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
I have the same Problem. If you disconnect the battery manually, IT works until the next new start.
I think it is a cable Problem of the White Long cable inside Phone.
Punteggio 0
2 Commenti:
Do you mean the white antenna cable?
da
Yes. That’s what I think. It looks not so good, but I’m not a pro with such that :)
da
Aggiungi la tua risposta
Simon Olsson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 40
Tutti i Tempi: 579
