Salta al contenuto principale
Repair guides and documentation for the Google Pixel 5a with 5G smartphone. Released in August 2021.
How to check if it is original phone
i know that way of repair then put imei. it doesnot work any other way
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
@team06 Here's one way to check that the device is unmodified and from a reputable manufacturer:
  1. Open the Play Store app. If you need to, you can sign in using a throwaway account (Don't sign in with a Google account you use for important things)
  2. Once you go through the process of setting up the Play Store, select your profile in the top right corner
  3. Select "About" and look what it says under "Play Protect Certifocation". If it says "Device is certified", you're good. If it says "Device is not certified", the phone is fake or has been modified.
Punteggio 0
2 Commenti:
thanks for the guidance.
da
@team06 You're welcome
da
Aggiungi la tua risposta
Team06 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 250
