Salta al contenuto principale
The Amazon Kindle 8 is an e-reader that was released by Amazon in 2016. It was designed for reading e-books and digital documents by providing a simple, lightweight way to access and carry a personal library of books.
tailles du tournvis / screwdrivers sizes
Bonjour !
Cpnnaissez-vous la tailles du tournvis en étoile ( philips? ) pour le démontage ?
Hello !!
Do you knows the screwdrivers sizes ?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@bastienbastien I believe the screwdriver size you need to take apart the Kindle 8 is a Torx T5. If you don't have this screwdriver, you can get it standalone ( T5 Torx Screwdriver ), or as part of the Minnow Driver Kit and up, or the Essential Electronics Toolkit and up.
Je pense que la taille d'un tournevis dont vous avez besoin pour démonter le Kindle 8 est un Torx T5. Si vous n'avez pas ce tournevis, vous pouvez l'obtenir seul ( T5 Torx Screwdriver ), ou dans le cadre du Minnow Driver Kit et mieux, ou de la Essential Electronics Toolkit et mieux
Immagine Precision fixed blade screwdriver engineered by iFixit.
Prodotto
T5 Torx Screwdriver
$5.49
Immagine Our gateway kit to electronics repair, perfectly sized and priced for essential electronics repair.
Prodotto
$23.96
Immagine The Minnow pocket-size polymer driver and portable precision bit set is our smallest kit ever! 16 precision bits and a 4 mm driver for repair on the go.
Prodotto
Minnow Driver Kit
$11.96
Punteggio 1
3 Commenti:
Malheureusement, j'ai déjà essayer le T5, qui semble bien trop gros.
Unfortunately i have ever try the T5 ... without any result ( too big )
da
my bad !
T 5 working Good !
thx a lot
da
@bastienbastien You're welcome
da
Aggiungi la tua risposta
Bastien Bastien sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 189
