Salta al contenuto principale
La terza generazione di iPhone SE è stata annunciata l'8 marzo durante l'evento Apple Peek Performance. Ha un chip A15 e uno schermo LCD da 4,7 pollici,
Texts are going through as emails
My text messages keep go through as emails. When I go to settings, messages, iMessage. I can’t choose the phone number option. It doesn’t save it and goes back to the email. Does anyone have any suggestions? The calendar is set to automatically update as well
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Risposta Più Utile
@johnmac22911, Not sure if you turn your phone off after updates or even every few weeks to let it reset. But, it's a good practice to do so.
The first thing I recommend doing is shutting off your phone for 5 minutes. Then turn it back on and try and send a text message. See if it sends it from your phone number. Sometimes doing this simple reset can fix the issue.
This next thing might seem obvious, but I have to ask. Is your phone using a cellular network? (Sometimes folks use their phone on WiFi only). If it's on a cellular network, then I would go back into the Settings > Messages > Send & Receive > Click on the Addresses and double check that the, Start New Conversation From box with your phone number is the one that is checked.
If there is a check mark next to your email, then uncheck it. Then click out of messages to go back to settings. Then try sending a text message to test if the settings work.
Punteggio 1
2 Commenti:
Thank you for your reply. I tried everything mentioned. The issue seems to be when I uncheck my email under the messages portion of settings.
My phone number shows, however, I’m unable to select it. The wheel simply spins next to my phone number then stops. A check mark doesn’t appear.
da
@johnmac22911, you're welcome. I'm sorry this didn't work. Have you tried turning Messages off and then back on again?
Go to Settings > iMessage > Toggle Green Switch off.
In my experience it's better to turn iMessage off and then press the back button to go back to the main settings menu. Then wait about a minute and then return back to the iMessage settings to toggle the switch back on.
da
Aggiungi la tua risposta
John Mac sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 176
