Salta al contenuto principale
Modelli A1419 / Fine 2012 / Processori 2.9 & 3.2 GHz Core i5 o 3.4 GHz Core i7, ID iMac13,2
Which LCD screen should I look for?
Hi
I have a late 2012 27 inch iMac and the bottom left and right LED banks are failing. I am getting the fan shaped dimming on the screen.
I am just wondering if that year iMac has a specific screen that I need to be looking for or are there others that are compatible?
I don't really want to separate the screen from the body as yet as I am still using the iMac daily so I can't get to the part number.
The model iMac is A1419 and the EMC is 2546.
Any help would be greatly appreciated.
Questa è una buona domanda?
Punteggio 0
1 Commento
Thankyou for replying. I've done a few screen swaps in the past but I wasn't sure if screens were specific to EMC and model years etc. Apart from the 4K and 5K screens, I just assumed they would work.
I didn't know that the LED's can be replaced.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You do need to use the correct display assembly for your system, here’s the guide to properly get it off and the steps to install a new one Sostituzione schermo iMac Intel 27" EMC 2546 and here’s the needed part iMac 27" LCD Display Panel & Front Glass Assembly (12/13) keep an eye out as they pop up! They will be used as they are no longer being made.
Even still, you might find a used system to salvage the backlight unit and just swap it out.
Punteggio 0
1 Commento:
da
Aggiungi la tua risposta
Sheldon Griffin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 178
