Repair guides for the Portacool Cyclone 130, an evaporative cooling fan with model number PACCY130GA1 or just PACCY130. This fan was released in 2019, and is part of the Cyclone series of Portacool fans.
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
1 Commento:
Most fans use plain bearings described as sintered bronze with permanent lubrication. However, plain bearings sometimes need oil lubrication. if you can clean off debris and have access to both bearings, try some light oil and spin the fan. If oil seeps into the bearing, the fan should turn freely.
da F Dryer
