Salta al contenuto principale
Released in June 2017 as a successor to the Surface Pro 4. Also known as Microsoft Surface Pro 12.3". Model number: FJT-00001.
20 Domande Visualizza tutte
Can the digitizer cable in the display be repaired/replaced?
When opening the computer to replace the battery, I ended up damaging the digitizer cable on the LCD screen. Any way this can be fixed or replaced?
Screen works perfectly, lost the touch screen functionality though :(
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
I'm so sorry this happend! It looks as if the display cable is part of the display. Try pulling gently up on it, and if it doesn't work, I think you will need a new display. You might be able to find a cable somewere and solder it, but that would be very hard, if possable.
Punteggio 1
2 Commenti:
I appreciate your suggestions. Replacing it does seem like the best option, as attempting to solder without the right equipment can be very challenging. Unfortunately, I don't have access to a microscope. I'll look into getting a replacement display and hope that resolves the issue. Thanks again for your help!
da
@soryn no problem! Glad I could help.
da
Aggiungi la tua risposta
Soryn sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 67
