Salta al contenuto principale
An SSD, or Solid State Drive, is a type of storage device that uses NAND-based flash memory to store data.
mz-jpu512t/0a6 enclosure
Hello,
will this item fit a samsung mz-jpu512t/0a6 ssd (from a 2013ish imac)?
External M.2 SSD NVMe Enclosure
I didn't see any way to ask this question on the product page.
I extricated the drive and ordered what I believed was the correct enclosure, but I was mistaken. Looking through enclosures here and on amazon, I cannot find any that will fit this ssd.
Any help--any!--would be appreciated.
Thanks!
Immagine Use an M.2 SSD as an external drive in this enclosure. USB 3.1 transfer speeds up to 10GB/s
Prodotto
$19.99
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Is it the PCie based SSD? If it is, you should be able to buy an adapter. However, I do not believe that the product will out of box fit the SSD, and you will need an adapter.
Punteggio 1
Aggiungi la tua risposta
Pat Foster sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 276
