Salta al contenuto principale
The LG Dare is a CDMA touchscreen phone, released in 2008. It is identifiable by the model number VX9700.
How do I remove personal info from nonfunctional phone?
I cannot get the phone to power on to wipe it and do a factory reset. What parts of this phone hold any private information (images, messages, etc.)? I would like to turn the phone into a recycling center but would like to remove all of my information first.
Questa è una buona domanda?
Punteggio 0
1 Commento
I was able to take it apart and went ahead and took another phone apart as well, so here is both. I could not add an image to the comment so I added it to the initial question. Thank you for your help!
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Not much; what I've done before is drilled through the flash to quickly get the job done when someone asked me to deal with these phones or I need to get rid of one myself; it doesn't wipe out the contents, but it makes it impossible to recover. I usually go through the board, not just the flash. GENERALLY, I do one large hole and physically hammer the flash chip to be sure.
At that point (depending on who I did it for; me or someone I know, or a client), I handle it case by case:
  • Personal device: Heh, it can wait
  • Good friend: I warn them I will not burn the gas for one phone (NOTE: I can and do make exceptions for data-sensitive devices, I'm not that insensitive but no I'm not wasting gas on a personal phone with zero recovery chance) that day, but if I know I need something or I need to go somewhere NEAR a BB or other store who I can verify takes them I'll let them go with me if they need transportation. If I'm going to pick up something I grabbed as a pickup like an R10 for example I'll work with you at that point, then you can hand the phone in.
    • This isn't to be rude, and I've ALWAYS been clear about this; gas is too expensive enough of the time to casually drive you to BB for a phone that is physically unrecoverable. Using it to grab a new toy is different.
  • Client: It gets done (different situation; they come first). If I have others, the client's phone goes in the pile.
That said, once you do the dirty part put the board back in the phone. Don't make the person taking it explain why there's a hole in the board. They don't need to know. If you can open it to drill it you can put it back together.
Take a picture of the board so we can see where the NAND flash is.
-- should be under here on the metal shield. On the black sticker phone, peel it up and see if you can't tell by feel.
This is how it should be done. For context this is a router from the Draft N era (~2007) I was asked to drill through for disposal. Absolutely not needed but the person who asked me to deal with it wanted to be sure. Normally I'd fight back a bit and reset it but Draft N is dead and almost none of the specs made it into the final N spec. Draft routers are very often DOA; this one ran a super early revision and was DOA when finalized.
Punteggio 2
I was able to take it apart and went ahead and took another phone apart as well, so here is both. Thank you for your help!
Punteggio 0
5 Commenti:
Remove the big metal shield. It's under there. For the black sticker phone peel that up and see otherwise it's naked on the other side.
For reassembly don't worry about replacing the shield or tape. Throw it away and put it back in the phone without it for recycling. I doubt they will care.
da
@nick How can I tell which parts are the flash memory? I'm having a hard time telling which parts to destroy. I have updated the photo. Thank you in advance.
da
@phonenomore Phone on the left is the one with the white sticker most likely. Others look like accessory chips like the processor and cellular radio. I can tell by the white dot with that one.
Do you see something similar on the right side board? Check both sides.
Qualcomm on the right board is a cell radio or processor. Disregard it. The flash may also be next to the Qualcomm part as well, but check and see. If you see no other major chips (small ones like the ones towards the top are for the other circuits) it could be the flash.
da
@nick Thank you so much! I was able to I think, figure it out, with your help. I will be taking it to a local business to drop off very soon! Appreciate all the help and explanations.
da
@phonenomore Heh I've always dropped these things off to Best Buy when I have a time slot or I'm buying something there. I usually reassemble the phone to avoid being questioned about why I didn't just trust them.
They don't see I drilled? No problem.
da
Aggiungi la tua risposta
phonenomore sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 29
Tutti i Tempi: 310
