Salta al contenuto principale
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Domande Visualizza tutte
Why does my Airport take so long to connect?
Sometimes, when I open my MacBook, it takes a few minutes to find any wireless networks. On other MacBooks, it takes a few seconds. Sometimes, my MacBook finds a network right away, but sometimes, it takes forever. How can I fix this?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
This may or may not be a factor but go to system preference, network, then click on advanced. in the first tab, under airport, check out how many preferred networks you have listed, get rid of any that aren't networks you use regularly and finally if you're left with more than one network drag your home network to the top of the list.
hope that helps
Punteggio 3
2 Commenti:
I've done this before, and it worked a little. I'm trying it again, and I'll see how it goes after a few days.
da
It totally worked!
da
Mine has the same issue, started happening after i upgraded to snow leopard. I haven't found the culprit of this yet... although when i changed the network configuration away from a 128WEP to a wpa it started connecting right away 95% of the time as opposed to 60% before...
Punteggio 0
Aggiungi la tua risposta
Sterling Hirsh sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 2,540
