Salta al contenuto principale
A wire is a single, usually cylindrical, flexible strand or rod of metal.
3 Domande Visualizza tutte
3-way switch replacement help
I am trying to replace a double pole switch that is a few years old.
One pole is just for the porch light and one pole is for the hallway lights that has a switch on first and second floor as well as the this one that is by the door.
However, the new 3-way switch that I bought looks a bit different and am now confused as to which wire goes where.
Any help or info would be appreciated!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Give this a read How to wire a three way switch
It can be a bit confusing and depending on colors of the wires your house wiring uses the two messager wires can confuse
Punteggio 0
Aggiungi la tua risposta
Al mirani sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 61
