Salta al contenuto principale
Released in 1999, successor to the original PowerMac G3, 300-450 MHz, 64 or 128 MB of RAM, 6 or 12 GB HDD
What are these 8 pins on the back of the cpu
Cpu says XLR8 MSG4Z400 I’d like to overclock this but cant figure out how
Questa è una buona domanda?
Punteggio 1
2 Commenti
@thomas35549 not sure which pins you are referring to. This is where pictures would definitely help. Anyhow, for the overclocking (really not repair related) check sites like this or this one right here
da
Ok I added a picture
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@thomas35549 just going by the number on this board as well as the partial picture, it appears as if you are talking about a daughter card which would have taken over the original CPU. The one you have appears to be a XLR8 ZIF Processor Upgrade. In that case, the jumpers would adjust the backside bus speed and ratio. According to the manual here are the settings
This would be the manual Mach Speed G3 ZIF you need, to figure out what to do with your card
Punteggio 2
1 Commento:
Thank you this is perfect
da
Aggiungi la tua risposta
Thomas sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 183
