Salta al contenuto principale
Why is my laptop keyboard is not working
my hp laptop ProBook 6560b's keyboard and mouse is not working.first when i turn on the pc the keyboard works well but after i press enter at the start windows the keyboard and mouse doesn't work
Questa è una buona domanda?
Punteggio 1
2 Commenti
Have you tried plugging in an external USB keyboard and mouse to see if they work?
da
@aactech yes the external mouse is working but the external keyboard don't
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Here are some possible solutions.
Do they work in the BIOS page? If yes then it could a Windows driver issue. Check in the Device Manager. They may have or not have an exclaimation mark by them. Regardless just uninstall them and let Windows re-install them.
The other thing could be the keyboard locking. Not sure if on your model. Try pressing and holding the right Shift key for 8 seconds. Doing this should unlock the keyboard. One of those "features" on some HP machinies!
Turning off Cortana also sometimes helps.
Disabling ctfmon.exe (Windows Collaborative Translation Framework), which is for multiple input methods, may also work.
Another thought. Does the onscreen keyboard work? Look in Settings.
Let us know how it goes.
Punteggio 2
Has someone worked on the laptop and opened the case? If so, it may be a simple as the keyboard is not plugged into the motherboard.(We should be so lucky).
If the external and the internal keyboard don’t work, the translator chip needs to be replaced.
Punteggio 0
Aggiungi la tua risposta
Nati sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 371
