It doesn't open
When I charge it shows me the apple logo and it will be power off and again it will show me the apple logo again and again
Questa è una buona domanda?
I’m sorry to hear that your iPhone 8 is stuck on the Apple logo. This can be a frustrating problem, but don’t worry, there are some possible solutions you can try.
One of the simplest things you can do is to perform a hard reset on your iPhone 8. This is a way of forcing your iPhone to restart when it’s unresponsive or frozen. To do this, follow these steps:
This may fix the problem and allow your iPhone to boot up normally. However, if this doesn’t work, you may need to try some more advanced methods.
Another thing you can do is to back up your iPhone using iCloud or iTunes. This will help you save your data in case you need to restore your iPhone later. To back up your iPhone using iCloud, make sure you have a Wi-Fi connection and follow these steps:
To back up your iPhone using iTunes, you’ll need a computer with iTunes installed and a Lightning cable. Follow these steps:
After you’ve backed up your iPhone, you can try to update or restore it using iTunes. This may fix any software issues that are causing your iPhone to get stuck on the Apple logo. To do this, follow these steps:
If none of these methods work, you may have a hardware problem with your iPhone 8. In that case, you’ll need to contact Apple or a certified repair service for help. You can find more information about how to do that here.
I hope this helps you fix your iPhone 8 stuck on the Apple logo. If you have any other questions, feel free to ask me. 😊
@kingofspades how can you back it up if it boot-loops?
@eyoel81128 since this happens when you have it plugged in to charge, it maybe an issue with the charging port or the charging flex Sostituzione gruppo connettore Lightning iPhone 8 Make sure you have a good charging cable and the right AC charger. Oh yeah, while you are at it, change the battery as well.
You can use something like 3uTools to get your phone into either DFU or Recovery mode. Check the 3uTools website for tutorials on these modes and when to use what.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 95
