Salta al contenuto principale
Released November 2018 as an edition to the iPad's Pro line. Model A1980.
How to fix my bend screen
How to fix my bend screen How to fix my bend screen
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Per my understanding from Alisha (@flannelist), who used to be an Apple technician, Apple does not actually repair iPads; they only offer basically a trade-in allowance.
I have, however run into a similar situation with an iPad my daughter-in-law got for free. it had a slight bend in it that resulted in a cracked screen and I went to the trouble to locate a replacement housing before I opened it up, but held off on ordering it.
As it turns out I didn't need the housing as the bend was minor enough that I was able to straighten it perfectly by hand so when I put the new screen in it fit perfectly.
@dao9418, post some pictures of your iPad with its bent screen and we'll see if we can figure out what you should do next.
Punteggio 2
1 Commento:
Correct on the repair front and ditto for iPad housings, they are usually soft enough to bend back into shape without too much work. (or out of shape when struggling to get them open)
da
Well, you see, it's not just the screen that gets bent, it's the chassis as well, and I don't know of anyone that sells replacement chassises. You could try taking it to an Apple store, but I doubt they'll be able to fix it.
Punteggio 1
Aggiungi la tua risposta
D. AO sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 190
