Salta al contenuto principale
Released on June 23, 1996, Model NUS-001, 64-bit gaming console
103 Domande Visualizza tutte
How do you clean the connectors on the jumper pack?
I'me having trouble getting it to worck. It is very finicky. So I wiglled the jumper pack around a nd the screen changed slightly in color. So I tok it out and turned the consoule on and the screen was the same color now as it was when it was in, so I tok a look at the connectors and they were bad (after turning the consule off of cource). Some of them were'nt even gold in color! Do you have any idea on how to polish them up?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I'd use some isopropyl alcohol and cotton swabs. You should have If you have enough room, to use a pencil eraser as well. Those work great to remove some of the grime. Hope this helps, good luck.
Punteggio 2
Aggiungi la tua risposta
David Boyce sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,575
