Salta al contenuto principale
The Land Rover Defender (initially called the Land Rover Ninety and Land Rover One Ten) is a British four-wheel drive off-road vehicle developed from the original Land Rover Series launched in June 1948.
Noise when clutch pedal is depress
Landrover defender 130 td5 after i have replace the clutch kit and thrustbearing when i depress the clutch pedal there is a noise sound like gears running with out oil but with the clutch pedal still depressed and selecting 2nd gear the noise go away but when i select any other gears the noise comes back even when in neutral but when i release the clutch pedal the noise is gone can it be something in the gearbox or the spigot bush that cause that noise. Thanks Max.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Without more info on what kind of clutch system you have I would have to say you probably need to bleed the clutch system at the slave cylinder
Punteggio 0
1 Commento:
I have fitted a new clutch kit and thrustbearing a new clutch master cylinder and a new clutch slave cylinder the clutch have been bled about 3 times already but the noise stay there.
da
Aggiungi la tua risposta
Max IRMSCHER sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 11
Ultimi 30 giorni: 44
Tutti i Tempi: 695
