Salta al contenuto principale
The Samsung Galaxy Note II is a smartphone noted for its combination of a large display and software optimized for an integral self-storing stylus.
Phone doesn't charge even when connected to the microUSB port
When I tried to charge my phone's battery using a 9-volt 6LF22 battery and using the wires to connect the + and - sides of the internal battery, the battery worked. However, when I tried to put the battery into the Samsung Galaxy Note II phone, it didn't work.
I tried to charge my phone. There aren't any lights in the notification dots, the screen doesn't show the battery bar, and when I press the power button, nothing happens. Taking out the battery and putting it back doesn't help either. I recently used a replacement battery and a different charger, but that, too, doesn't work.
I checked the micro USB cables. It does have an electricity sound, thinking it was charging, but it wasn't. I checked the condition of the micro USB port and if there is something wrong with it. I don't know if it was a micro USB port issue because of the dirtiness or the tilting of the center.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @evanlei1
Here's the service manual that may help.
Go to p.13 (of 67 pdf numbering) to find the charging part troubleshooting flowchart and follow that to see what the problem may be.
The board layouts are on p2-p.3 (you need to really zoom in to find the component) and here is the start of the parts list
If a component is faulty, search online using the part number to find suppliers that suit you best
Punteggio 1
Aggiungi la tua risposta
Evan Lei sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 116
