Salta al contenuto principale
24" display; Built-in iSight Camera, Microphone, and Speakers; 1920x1200 resolution. Released October 2008, identified by model number A1267.
I have two displays with weird display images!
Anyone know if this is fixable I have 2 Cinema screen monitors that are this way.
Does not appear when the monitor is off. Only after it's turned on. Should I just chuck them?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Ouch! What you are seeing is the breakdown of the liquid crystal material that is sandwiched between the two sheets of glass that makes up the panel.
These displays are still highly sought! Just for there well designed and constructed. You can still buy a replacement panel for them which would be cheaper than replacing.
Punteggio 0
Aggiungi la tua risposta
MIlagros Ramos sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 75
