Salta al contenuto principale
The iFixit Precision Bit Driver is an aluminum or plastic handle that fits 4 mm bits. Found in the Manta, Mako, Moray, Mahi, Minnow, Essential Electronics, Pro Tech and Pro Tech Go Toolkits from iFixit.
Bit stuck in tool due to super glue
Hey, I made a mistake and let small drop of glue into screwdriver, now it’s impossible to take off the bit.
Any idea how to dissolve it?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hello! Have you tried rubbing alcohol or another solvent? Acetone is also quite good for dissolving adhesives, but im not sure how this would react with the paint on the driver. @aleks26378
Punteggio 0
2 Commenti:
I tried to put a bit into nail polish remover but no effect. Maybe rubbing alcohol could help. Thanks for the answer!
da
@aleks26378 No worries! Hopefully you have some luck with it.
da
Aggiungi la tua risposta
Aleks sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 161
